Originally Posted by amx1397
hay guys the SC will turn by the air being drawn through it even at idle,, if you take a rag you should be able to stop the (black clutch) 1 " thick right behind the sc pully,,, i would remove the belt and check every pully by hand you can also start the motor ti be sure it is not a lifter or something jim
