Old Feb 11, 2010 | 09:01 AM
32krazy!'s Avatar
32krazy!
Default Re: Flowtech Warlock
Originally Posted by kolevski
Hmmm you may have a point my other alternative would be replace the secondaries with straight pipes, and put this flowtech where my resenator used to be.
The only problem with what your saying is where would I find a cap to block the exhaust off when I'm not at the track lol
kolevski i did the res delete and the secondary cat dlete on mine. if you replace the resonator with the new muffler you really arent getting anywere as the resonator is a flow thru design.
like i said before your system is so easy why not a true dual with the magnaflow? then if you want a stright exhaust cutouts are an easy addon.
the caps are easy to fab . use the flange from the old cats and a blocking plate with a gasket.
