Old Feb 11, 2010 | 09:20 AM
BLKFIN's Avatar
BLKFIN
ADDICTED TO BOOST
Default Re: Bigger Rims, Stock look.
Originally Posted by cross><hair
How does it ride with 20's in the rear and 19's in the front? I would, of course, lower it at the same time.
I have the stock shocks and would say that is not much worse than stock. I hear the Koni's make the ride better than stock even with the 19s & 20s.
My rims are pushed out about as far as they can go without needing to roll the fenders. I thought about adding a 3mm or 5mm spacer just to see if it would stop the slight rub on the inside, and not cause the rub on the outside fender. The rub is so slight and only happens once a month or so....it has not been real high on my list to correct.
I actually wish my sat a bit lower.....
