Re: How in the F do you change the headlight bulb? Broken thumb edition.
Originally Posted by MAYAman
I have been trying now for an hour to get my drivers side low beam bulb out. There is a metal clip and then I tug on the bulb and it keeps running into the metal clip. Now its just hanging there and I can't get it back in or out. Nice design.
See my posts in the following thread. That should help. It really isn't that hard if you use a mirror and needlenose pliers. Should take 30-60 minutes or so to change all of them. I found it easier to totally remove the clip, but you do run the risk of dropping them. Some say you wiggle the plug to get it off. I would use the word 'pry'. It can take quite a bit of force to get it off. Almost a twisting motiion.
https://www.crossfireforum.org/forum...-question.html
