Originally Posted by velociabstract
I have a Dashdaq and have logged at the track. (mostly road courses) I don't know what gauges I need to be looking at besides boost for slip. I boost a max of 17.9 psi with my code 3 (aluminum) My car seems a touch slow for the modifications (best of 12.72 at 108) I assume it's slipping a bit because sometimes I don't make 17.9 psi but more like 17.5 but I don't smell the belt burning or see signs of slippage. Either way, I'm up for the kit just to be sure.
Les
do you have a tune for the c3? without a tune and some mods to my airbox and a set of dr's i ran a 12.7 along with bmorgan. after the tune bmorgan has cut a full .5 off his time. i havent been able to run due to weather.
i dont think its slippage but normal times for the mods you have
so the kit will be here next week. rob has outfitted me with some belts and the 178 psk to install on my slk32 with a c3 pulley. once all the belts are tried and the best for the setup is run for a couple weeks this should become available to the c3 crowd!! better bearings, bigger pulleys and a belt wrap all in one!!
pics and impressions to follow.
