Old Feb 15, 2010 | 03:51 PM
hcarter's Avatar
hcarter
Default Re: Radio cable Question
Originally Posted by rcompart
I personally would try mounting the antenna in the center of the windshield right behind the mirror off the the passenger side and see how that works. Use some double sided 3m tape, not the cheap stuff either, you'll thank yourself if you ever need to remove it. Either that or see if the antenna gets a strong enough signal that you can put it under the dash pad up by the vents. While it's not the easiest thing to do, not seeing any wires is in my book, always the best option. Good luck with the install.
Is it possible to get behind the glovebox with out much trouble that way i can put it up under the dash on that side and have no exposed wires except for about 3 inches at the back of the radio i can put the antenna in the floorboard and the reception is still good 3 bars so under the dash above glovebox should work as well,
