Thread: Will This Work?
Old Feb 16, 2010 | 05:52 PM
kurtisberry's Avatar
kurtisberry
Default Re: Will This Work?
Not enough info here. If it is a true single DIN it should fit. It is not plug and play. You will need a wiring harness to adapt the Xfire wiring to the headunit connectors. This needs to be assembled by hand, matching the correct wires from each together. I would suggest an installer if you don't know what you are doing.
Again, there is not enough information in the ad to determine if it will physically fit.
