Re: Any one know how to decode the VIN??
The VIN doesn't contain a build date but I believe I have seen higher build numbers than that with the problem. Regardless, the problem is there and the vehicle is under waranty. The dealer has to fix it!
Here is the VIN code FYI anyway, and now it will be listed for anybody else's future reference:
Keep us posted on the results. Good luck.
CROSSFIRE VIN CODE BREAKDOWN
POSITION INTERPRETATION CODE = DESCRIPTION
1 Country of Origin........1 = Manufactured By DaimlerChrysler Corporation
2 Make..........................C = Chrysler
3 Vehicle Type..............3 = Passenger Car
4 Other.........................K = Restraint System Front Air Bags Next Generation
.........................................(CGW) With Standard Side Air Bag Supplement (CGS)
5 Car Line.....................N = Crossfire (LHD)
.....................................P = Crossfire (RHD)
6 Series........................6 = “S” Series
6 - Export Transmission.C = 6 Speed Manual (DED)
.....................................E = 5 Speed Automatic (DGU)
7 Body Style.................9 = Specialty Coupe
8 Engines......................L = 3.2L V6 SOHC 18 Valve
9 Check Digit See explanation in this section
10 Model Year...............4 = Model Year
11 Plant.........................X = Osnabrueck Germany
12 through 17 Sequence Number 6 Digit Sequential Number Assigned By Assembly Plant
