Old Feb 19, 2010 | 09:26 PM
  #40 (permalink)
J-Groove's Avatar
J-Groove
Default Re: p0410 secondary air injection system malfunction solution?
Originally Posted by Larry Hitze
J-Groove, If that valve doesn't do it and sometimes you can hear the pump working right after you start the engine ( 30 seconds to a couple of minutes more or less) you might consider checking\ resoldering the contacts on the relay control module. It has a relay in it that controls the secondary air injection pump. It could be an intermittent connection in the solder joints. Search relay control module on this forum and read all about it. Tighed1 will solder it if asked nicely for beer money and postage. Contact him if interested. Just a thought before you buy expensive parts.
Thanks for the heads up and extra parts to check out!
I cleaned the contacts, checked the vacuum lines, looked for any and all corrotion that I could possibly find, which was next to non. Then put everything back together.
So far it has been a few days and no more CEL, but I will follow up with the relay board if the problem comes back.
-John
