Thread: Oil leak
Old Feb 21, 2010 | 09:47 AM
goodgenes79's Avatar
goodgenes79
Default Re: Oil leak
I had to replace the trans fitting due to leaking, and while I was under there, I cleaned everything up. I looked the othere day and found that the steering stabilizer is no leaking, so I need to fix that. I would like to do a tranning fluid change so both will be done while up in the air.
How bad is the leak? Is your dust cover on or off the car, to better tell where the leak is coming from?
