Old Feb 25, 2010 | 07:43 AM
danimal's Avatar
danimal
Default Re: Removing wires from low beams
Originally Posted by jediracer
I canget the clip off and the assembly comes out, But I was afraid to remove it with the wires still attached. They don't look like they extend that far. Now what release clip are you referring to? The clip that holds the bulb in?
James, there is no release clip for the wiring harness.....just the wire clip to hold the bulb in. The easiest way (that I found) is to leave the bulb clipped into the housing, and get a pair of long, needle-nosed pliers and grab the back of the black plastic connector and pull hard. If you start twisting it, all that you are going to do is break the connector. It does come off but takes some muscle.
