Thread: bad clutches?
Old Feb 28, 2010 | 10:42 AM
goodgenes79's Avatar
goodgenes79
Default Re: bad clutches?
Well I changed the fluid and filter yesterday. I ran as much fluid out as i could, by running it through the gears until it stopped draining. I was a bit leary running the tranny with no fluid for very long, but at idle I doubted much strain was on the parts. Anyway, i turned the TC over and over hoping to see a drainplug, but nothing. I think I got five or six quarts out, replaced the filter, wiped down the pan and magnet ( there was a bit of metal dust sludge), bolted back together, and added new fluid. I added as much as I drained but I really need to check the level properly, so I may run by the dealer to see if I can "borrow" a dipstick to check. I could and will eventually breakdown and buy a tranny dipstick, but not today.
I will say it shifts a bit better/stiffer this morning, so I have high hopes cleanign the system will have solved my immediate problems. Thanks for everyones help and opinions, and I will update if I find anything amiss.
