Thread: New rattle. :(
Old Mar 3, 2010 | 07:50 PM
04Fire's Avatar
04Fire
Default Re: New rattle. :(
Originally Posted by j-fire
i've go the same thing Cgocifer. my rear suspension after the koni install makes a knocking sound on bumps. never had that before until i installed the konis.....
Ditto! So is this just normal effects of the Koni's? I've replaced the koni's twice under warranty and the noise is still there. I've checked everything and it's all tight... however... I just had my lady drive me around the block while I was in the trunk and there appears to be two rattles: 1 is from under the car right around where the diff is (it's a rather heavy thud when I'm right on top of it) 2 is a slight thud under bigger bumps around the rear pass wheel well. But there is a constant low rattle while driving over anything other than completely smooth roads.
Any ideas are welcome as I've been living with this rattle for sometime now.
