Thread: Help Please!!
Old Mar 8, 2010 | 08:45 PM
kolevski's Avatar
kolevski
Default Re: Help Please!!
Originally Posted by 32krazy!
1202000470 is the part # for the small idler pulley next to the s/c. im guessing thats the 1 you need?
i wouldnt use the 6 rib pulley with the 8 rib belt it will prolley eat the belt or at least cause it to slip off.
as for the belt being 5 mm smaller thats quite a bit. when its installed look just behind the tensioner and you will see the slot were the tensioner rides. should be centered. to much either way may break the tensioner or the belt. this job is 10 times easier if you pull the fan out first. it takes seconds and gives tons more room to work in
Its the flat surfaced pully just under the S/C idler pulley, I think thats also called a idler pulley.
I figured it might not work aswell BUT I have the Code3 s/c pulley and thats I think about 6mm smaller then the stock S/C pulley so it should all balance it's self out (I hope)
