Old Mar 9, 2010 | 02:14 PM
Franc Rauscher
Default Re: How do the two grills below main grill come out?
Originally Posted by popeye
Got down on my 70 year old hiney and looked through the grills and all I see
is about 2/5 of the grill is solid. The passenger side has a square hole in that solid part, but I see no tabs. Driver side grill pretty much the same. I must not be looking in the right place.
I thought let me see if I can get at the tabs from under the hood, no cigar there either. Can one of you lead me by the hand and tell me where to look?
Noting that 2/5 of the grill is solid, not so sure painting it without taping off those solid parts so the whole thing looks like a grill would look so good. But if I can find a way to tape off the bottom of the solid squares it should look pretty nice....
Can I see these tabs of which you speak from the front of those grills?
Thanks Popeye
The tabs are on the grills.
Stick two fingers into the grill, right next to the center body part. Push to the outside of the car, left on the left one, right on the right one, and they will move sideways. Do a little twist, push and pull. They will come out.
Once you do it the process will seem simple and easy.
You can do this from the inside of the car by hittin' a bump, or a ramp, just right. I cannot guarrantee you won't scratch the parts so I do not reccomend it.
franc
