Old Mar 9, 2010 | 11:31 PM
  #44 (permalink)
Franc Rauscher
Default Re: The truth about "ram air"
I'm almost positive that a boost gauge on a naturally aspirated car's intake tube would read 0 psi (maybe a fractional increase, but nothing worth looking at) no matter how it is positioned. As you mentioned, there is a vacuum inside the engine, which as you said is a giant air pump... that's the only real pressure difference. If you held a pipe with a ballon duct taped to one end out the window, it would not fill up the balloon.. The air would occupy the balloon until the point that it needs to be compressed, then "new air" would flow around the contraption.. The pipe might fly out of your hand because the air is at a higher velocity relative to the pipe. Having a large pipe with a small hole on the end is a nozzle.. that's a different story than ram air. Air will not compress itself.
A nozzle is just a small piece of pipe unless a fluid is being forced thru it. That takes pressure. At least it does here in Missouri.
There are no moving parts in a ram jet engine except, the ram jet engine's movement thru the air. Therefore a ram jet engine has virtually no thrust untill it achieves some velocity.,,,,,enough to form compression in what engineers call the "compression chamber"
A ram jet won't even start unless air is flowing thru it.
Air can be compressed by movement of the collector, or ram, thru the atmosphere
roadster with a stick
