Re: Best Size Spring Pads!!!
With the dot 5 in the front and dot 1 in the rear, Koni's and Eibach's the car will be approximately 1/2 inch lower in the front and 1 1/2 inches in the rear. If you lower more in the front you could have some rubbing. I have this setup but with tires that are 4mm taller and I have some minor rubbing. With stock tire size in the front it should be perfect.
Les
