Re: Koni/Eibach Combo Installed - Rear is slammed ?
Bmorg, Anthony,
First, thanks for getting back to me.
Second, apologies on posting pics - no can do, work computer and all.
Third, With steering wheel level car steers approx 4 - 6 degrees (S.W.A.G)left (before lowering install). Am hoping to get that adjusted out. Doable ??
Fourth, What could/should shop (dealer performed install - they ain't gettin another crack at her) check for to verify correct install ?
Fifth, Best case scenario, install correct. How much lift/space/distance does a 2 dot 9mm pad set get me ? 3 dot 13 mm ?
Sixth, Thought I saw on the forum the stock pad sizes were 2 dot 9mm front, 3 dot 13mm rear. The 2004 parts manual available on the forum lists the rear spring "isolator" as 1 "burl" ?
