Old Mar 17, 2010 | 06:52 PM
mjgroves's Avatar
mjgroves
Default Re: The quest for a "perfect" crossfire, need help with my "TSB's"
Ha, I bet that was a rush.
Thanks for the advice guys... I'll try wrapping more tape on the contact point... it didn't fix it for me the first time but maybe I taped the wrong spot or something.
I'll report back with my results.
Originally Posted by XF1RE
I would try to fix this issue yourself with the "electrical tape" remedy for the trunk latch and getting some automotive grade foam and attaching to the inside of your trunk where the rubber bumpers on the latch contact the bottom. This same rattle was what I took my car to the dealer to fix and all they did was lower the bumpers(you can see they are adjustable) so the trunk moved less over bumps, etc. Though this fixed the problem, less than 24hrs later I hit a bump that opened my hatch, it wouldn't close again until I took it back to the dealer(then the rattle returned....). Moral of the story- this forum is so much more helpful than a dealer!
