Old Mar 19, 2010 | 02:50 AM
speaks2all's Avatar
speaks2all
Default Throwing P2099, P0171 and P0174 same time
I have installed new plugs Bosch (12 at 7 dollars a piece)
I have installed new upstream and downstream O2 sensors OEM Bosch
New OEM MAF (thought K&N oil messed it up I had light spay on them)
Put new OEM air filters and took K&Ns out
New OEM Fuel Filter
New exhaust flanges and donuts
2004 with 61K completely stock
Cleaned injectors
Did vacuum leak test
Fuel delivery pressure at about 49-52 psi
On OBD II with MIL on everything ready
'Evap
Cat
Misfire
Fuel
O2s
H02s
EGR
Took to Mercedes guy and he is scratching his head.
What is most odd is I clear codes run car down freeway 80 miles no MIL
Stop to to off tank ant Chevron and MIL comes on half way back home....throws three codes mentioned in subject line
Smog guy puts sniffer in pipes and says all OK but cant pass because of MIL
The P2099 code (and P2096) showed up after Chrysler put warranty tranny in car two years ago
any ideas??
