Re: drivers seat inop
Hey guys . . . I seem to recall when I took my seat out to repair the heater, that the connectors have a spot to slide a tie wrap around them to hold them in place. It may be possible that this tie wrap is broken from your connectors, allowing them to pull apart. If you are able to, I would suggest pulling the seat up from the mounting (once you get the bolts out) and then take a tie wrap to hold the connectors together - just like the factory did . . .
Just my Two cents worth . . . .
Cheers
Mark
