Old Mar 20, 2010 | 11:12 AM
oledoc2u
Default Re: How do I Jack up my XFire with a FLOOR JACK???
Originally Posted by cassidyrj1
Ya it was my first crossfire. I slid into a very steep ditch that was about 10 feet deep. Dont worry it wasn't a result of jacking my car up.
and you walked away...these little dudes are tanks...my roadster is so stiff, I can lift 3 wheels off the ground if I wanted to, but I don't. I raise her up, and I have cut pieces of 2x4's as a block to set on top of the jack stand to prevent any damage to the car. I place the jack stands at the four corners where the jacking blocks are. I do these one at a time. As for changing the oil, or installing a steering stabilizer, you only need to jack up one side...right side for oil changes, left side for steering stabilizor...when I changed my brake fluid, I put up on all fours...did a gravity drain overnight. Painted calipers, put in fluid....will be doing the coupe next...
