Old Mar 26, 2010 | 04:19 PM
maxcichon's Avatar
maxcichon
Default Re: Can our cars take 55w hid?
Never replace a fuse with a larger one. Ever. In this case you should not need to.
This sounds like a case of an intermittent open circuit. Or a loose connection to the layman. Somewhere.
I had the same issue recently with my foglight HID's. It, in the end, turned out to be a broken wire in the base of the bulb. The bulb/glass envelope was fine-the wire came off the contact inside the base of the bulb.
It would work basically when it was cold. Would not re-light.
Good luck.
