Old Mar 30, 2010 | 12:56 AM
GDrag's Avatar
GDrag
Default Re: Ran a 14.8 at the track
Decent run for damm near stock. Better than the 15.5
Throttle reset works don't it?
NOW,
You need stickers. Flames work well and cut seconds off your trap times.
Get some cold air going through, a tune and maybe some bigger injectors.
I hear on the 04 you can pull the fuse on the trac control. Not sure but think Firemax suggested it.
A little tire spin ain't bad. Chirp in second and third means you are shifting within the power band
roadster with a stick
Hey Franc,
Are you in the 13's?
