Old Mar 30, 2010 | 10:16 AM
nox1s's Avatar
nox1s
Default Re: Can our cars take 55w hid?
Originally Posted by Crossfire725
ok well try. i orderd a new relay kit. going to try that. i notice every other time i turn the lights on about both light. idk maby unequal power at some points. maby more to one then the other at times? is there a way to not use the stock harrnes an get like a fog light kit orta h7 kit and run it myself so i has nothin to do with the comp? would that help? idk just trying to make this a faulless system. I NEED LIGHTS lol
You should try and do some more troubleshooting before you go ahead and replace / buy / do anything else.
Try swapping the bulbs from each ballast, swap the ballast on either side..
See if you can identify if it's a bad bulb, bad ballast, or if it's a problem in your cars electrical system (which I highly doubt given the nature of these HID's)
(btw, you know our N/A crossfires have absolutely nothing to do with AMG right? you might have the worlds largest AMG sticker on your car that isnt even an AMG.. )
