Old Mar 31, 2010 | 12:39 PM
rcompart's Avatar
rcompart
Default Re: Check oil light on after changing oil and filter
But I put in only 8 quarts the last time, and now I don't get a "HI" alarm every time I take a curve too fast.
Not saying to only put in 8 quarts, but that's what I tried and it worked for me. NEver seen a low oil alarm light.
Are you parked on level ground when you change your oil? Also, are you pulling the oil filter out prior to putting the drain plug back in? First oil change I did I wasn't perfectly level and I was in a hurry so I didn't let it all drain out. it's amazing that half a quart of oil will come out eventually if you let it sit for 15 minutes.
