Old Apr 1, 2010 | 01:33 AM
818.crossfire's Avatar
818.crossfire
Default Re: Button under accelerator? Stock or Moded?
I had to go out and try the OMG[SIZE="4"] button, and it works.....geez, impressive. I am impressed with the power of this vehicle, it lacks the bottom end im used to in my v8's but the mid power is impressively smooth, love it.
I took a closer look at the seat, moved it all the way up and noticed the previous owner left a deflated mini football under the seat, so I got that situated. Seeing that much taller dudes were making it work I had to do some research, better now.
One thing I am not used to is how stiff the suspension is, great in the corners but no so fabulous driving down LA streets, my cd's skip often. I am guessing the suspension is stock but never had it up on the racks so I dont know for sure.
I actually like not having "alot of options" for upgrades, the truth is ive had mustangs and camaros all my life and there was so much shi* out there I never knew what to buy, not the problem with this vehicle.
I am guessing there is no "supercharger" for this vehicle huh? something I could build the bottom end with? And as far as nitrous what is the system to use in my NA crossfire?
Btw what is NA?
What does the ST stand for on the front and rear emblems?
If you are the only driver of the car, do you need to reset the throttle system every few weeks? I am the only driver.
My car has this crap on the inside panels, and it appears it is peeling off (diamond pattern covering around gauges and switches. It appears these are aftermarket sticker covers to cover up the interior panels, or is this stock? If I were to take them off would the adhesive be a bit*h to remove? anyone have experience?
