Old Apr 1, 2010 | 03:30 PM
BoilerUpXFire
Default Re: Did my amp blow or what!?
Originally Posted by jediracer
Did that! Actually........this morning when i got in the car, everything worked fine. but after a few minutes, the sound became intermittent. Eventually going back to just hearing the rear speaker again. AMp or radio is the question. I'm getting a new radio regardless but would love to have this issue straight before installing it!
I would check all the connections at your wiring harness. I assume you used the scoche VW harness to tie everything in without having to cut any wires....
I would be weary of taking it to the dealer, b/c with your aftermarket deck, they will simply blame you or the install shop and not cover anything because modifications have been made (however minor). I would slide the factory deck in there and see how everything works, and if you still have the same issue, take it to the dealer with the OEM deck and you will have NO issues. Then when you get your new deck, you will be certain there is nothing else going on and you can enjoy it
