Old Apr 3, 2010 | 09:11 AM
psuperti's Avatar
psuperti
Default Re: Zex Nitrous install, with detailed step by step pics
Originally Posted by 818.crossfire
I have been checking out the thread, I think you guys might be the right dudes to talk to. I have an 04 na with 38k on it. I want to shove a little power into it now. I am thinking nitrous, as if I dump too much money into it I mine as well go buy something else. What can I throw into a stock motor and not blow her up? if the motor had a few motor mods how much more power could I pour into it? Any help or opinions are greatly appreciated!
A shot of 75 HP from a wet kit on a stock ECU or you will need a custom tune, injectors, better fuel pump etc. ( I have two fuel pumps on my Two stage 125 HP). Unless you are using NOS at 90 degree weather you will need a bottle heater too (to bring it up to 1000psi). I got everything, heater, opener, gauge, WOT, purge, tune, injectors, secondary NOS fuel pump, better spark plugs, modified intake silicone elbow to hold the shark nozzles for $3000 total. My dyno this week gave me 257 HP to the wheel (before any adjustments) on the xfire limited. Good luck!
