Thread: Koni Install
Old Apr 3, 2010 | 05:36 PM
32krazy!'s Avatar
32krazy!
Default Re: Koni Install
boy did you hit the jackpot today!!! im in the process of doing this with konis' as we speak. a biatch of a job if you cant read chinese mumbo jumbo!!!
you will need the rubber bushing from the top of the old shock, the sleeve and the yellow bushing under the sleeve. i didnt know this and as a result i have mounted these konis' 3 times!!! on my 32 i had to drill the hole in the top of the sleeve a bit to fit the new shock.
remove the top shock bolt with the weight of the car on it. after you remove it raise the rear and remove the shield from the lower control arm. remove the lower shock bolt. jack the arm up till it bottoms then release and grab the shock and jerk it out of the top housing quickly!!!! i dont have enough strength to compress the shock in the tower.
reinstall the new shock with the yellow bushing then the white cut washer the sleeve then the top bushing. install shock then the metal sleeve in the hole then lock washer then bolt. if all goes well you should be done
