Thread: Koni Install
Old Apr 3, 2010 | 06:22 PM
velociabstract's Avatar
velociabstract
Default Re: Koni Install
If you know what to do it's easy. You do need to reuse the black dust cover or "hat". The shock rods on the Koni's are larger than the stockers so you need to drill them out which I found to be the hardest part of the job. You reuse the yellow bump stops which you will find under the dust cover. If your car is not being lowered you just slip them on the new shocks (takes effort because of the larger rod) The rest is normal. Check out this thread.
https://www.crossfireforum.org/forum...ravaganza.html
Les
