Thread: Koni Install
Old Apr 3, 2010 | 09:27 PM
32krazy!'s Avatar
32krazy!
Default Re: Koni Install
Originally Posted by velociabstract
Maybe your suspension is stiff because it can't travel like mine!
https://www.crossfireforum.org/forum...e-img_0346.jpg
I have Eibach's with Dot 1 pads and adjustable camber links and my swaybar is hitting the frame and the camber link. Check yours and let me know.
The bump stops are a protection for the shock. If you don't cut them you won't have full travel before hitting the stop. But if the sway bar is hitting the frame and upper link then it will never get near the bump stop.
I would just follow the instructions and do the final tightening on the ground.
Les
the oem springs on my 32 are eibachs and had dot 2 pads. actually saw some rubbing when i removed the wheels but the shocks have 50,000 miles so prolly wore out.
the new setup is b&g springs with dot 1 in the back. rear has great squat now and set for stiff ride for now. tvt camber bars installed for the alignment. the fronts actually look the same if not a tad higher than stock. fronts had eibachs as oem and dot 2 also. now b&g springs again with dot 4 pads.
