Originally Posted by BRappaport
maxcichon,
Thanks...That's an easy way to access the bulbs. Once I did the lid trick, I was able to reach the bulb and turn-it a quarter turn and it was loose, but the wires are too short so I can not get the correct angle to pull the socket and bulb out. Any suggestions as to how you got yours out.
Thanks
Ben
There is just enough loose wire to pull my bulb out and do the swap. At least in mine. It's a contortionists trick to do it, but beats the heck out of having to replace $35 worth of one-use push rivets.
It's the only way I found to do it!
