Originally Posted by 32krazy!
i see. the power bleeder comes with the euro cap and has a press. gage to control the amount. pump it to 20 lbs and crack the bleeders. thats all you have to do. i never repump or add any fluid. just let it flow until clean fluid comes out. for me it was the only way to completely flush the system of air.
Maybe it was the one I used in the past but I did not care for it. I am sure it works fine as you use it.
The pneumatic vacuum pump with the auto refill was easier, maybe because I was using the compressor. The refill keeps the master cylinder full to the max line
not over.
The vac pump lets me vac out the old fluid from the MC before starting, so there is no pumping old fluid through the system first.
I can recommned the
MityVac MV6835.
