Thread: Fuel Filter
Old Apr 7, 2010 | 10:14 PM
onehundred80
Default Re: Fuel Filter
Originally Posted by smpshady
Ok so I know that the manual say to replace the fuel filter after 4 years, but with limited number of miles I know its overkill, but I'd like to do it anyways.
How often/ when did you, or plan to, change your fuel filter?
Rob at NW says its simply lift and replace, but the manual states to release the pressure, which may through a code.
Is it necessary to release the gas pressure, or can I just clamp and replace?
-Steve
Look at the shop manual for instructions on changing the filter, Yes release the gas pressure, the release valve is on the fuel rail.
But frankly why bother unless you know you have had bad gas, seems like a waste of time and money, but as both of which are yours ......
