Originally Posted by bmorgan
Go here:
https://www.crossfireforum.org/forum...ollection.html, and download the service manual. It will show you how to remove the subwoofer. It is on the lower drivers side, behind the seat. I purchased a set of the removal keys from Walmart a couple of weeks ago. It was a set of 3 or 4 different keys for around 5 bucks. Just look at the pic, there is nothing else that comes close to that shape.
I am asuuming when you say base, you mean base roadster, not base = floor, if that is so.....
Bob, you are usually not one for misinformation, but this time, you are off base (no pun intended
). A base roadster/coupe does not have sub in the rear wall behind the seats, it only has the 2 pairs of components in the front and a 2 channel amp.
What I did with mine was add another pair of components to the spot where the limited guys have the subs (on the wall behind the seats) and then add a pair of subs to the trunk and it sounds great.
While I am not nearly as well versed on the roadster, if you need some advice, let me know.
John
