Originally Posted by kolevski
Brian do you think theres a point to seperating the IC and the engine coolant unless you do it your modified way?
For example do you think the coolant seperate kit NeedsWings has will have any benefit? or do the IC and the engine coolant temp's remain the same? I've heard the IC temps should be about 20 degrees lower
