Originally Posted by oledoc2u
....What is a big deal is the trouble you are having...I am ready to shoot these manis off to Shelton to do his "thing". Have you diagnosed your problems w/ the modified car? ......l
Doc, I have not found the culprit yet... as I mentioned, I have ruled out the gas pedal and the TB (I think).... according to the service manual that just leaves a open, short or intermittent connection in the wiring. I am going to go out and re-solder the TB connector that I spliced in and see if I have a cold solder joint and check the wiring with a meter....
I'll let you all know what I find....
I think I will install the Dashdaq too and then take it for a run and see what the data logs look like too......
I wouldnt worry about the mods you are planning... I have been running mine for a year with no issue from them...
