Old Apr 13, 2010 | 03:12 PM
ZAHANMA's Avatar
ZAHANMA
Default Re: New Member with some simple ?'s
Originally Posted by 315er
I recently purchased a 2004 White, with an automatic, 35K and not a scratch on the car. Beautiful mint condition!!I can't express how happy I am with the machine. I've driven it approximately 2,000 miles now and have some simple questions that I could not find answered in the archives. I purchased it from a small independent car dealer.
  • The passenger seat does not raise & lower like the drivers seat?? Is that broken or only operates on the drivers side?
    Driver's Seat is 8-way, Passenger's is 4-way
  • When I start the car a numerber appears for a few seconds in the mileage display then the actual mileage appears. This # increases by incremunts of 100??
    If it appears as "-100" that means you are 100 miles past a service. Either one wrench or two. Once the service is performed search for FSS Reset and it will reset to '7000' and begin counting down in increments of 100 miles.
  • The traction control light (on the speedo) always stays dimly lit? Brightens when turned off. Should this always be slightly lighted up.
    I have found that if your cluster lights are on, i.e. daytime running lights then mine seems to be lit very dim from the ambient light of the other cluster lights.
  • I tried Google for GPS instructions for the Infinity radio? No real help there...Not that I care much abut it as I use a Garmin or my cell phone.
    Instructions to use or set-up? To set-up you will need the two (2) CD set for installing the maps, which has to be inserted everytime the battery is reset unfortunately. If the car did not come with these you may be able to buy them from another member who has replaced their OEM Headunit. As for instructions, check your manual...Then again, I'm with you and I just stick to my Garmin instead of the built in GPS in my SRT6.
Thanks in advance for the help....
Answers in red above...
Welcome to the forum, search for anything and it has more than likely been answered. There are tons of very very knowledgeable people on this forum about every in and out of this car. Happy driving.
