Old Apr 15, 2010 | 09:34 AM
BoilerUpXFire
Default Re: Wanna sub in my Base
Originally Posted by Road King Custom
Hello again!
Ok i bought a sub and tryed to install it with the pre drawn wires that i found in the trunk,
and yes the sub has a amp installed. Connected it all, and it did NOT work
Then i took out the radio and found that the cables was not connected to the radio.
After digging with my hand in the radiocompartement i found the cable that is going to the subs. But the contakt did not suite any connections on the back of the radio.
We called the contakt a bananacontakt, it,s those that you are using for stereo or tv, before the scart came.
-Now over to the big question. What do i need to bridge it to the radio and where should i put it. Does anybody have a picture or drawings from the back of the radio?
I,we been looking at the servicemanuals, and didn,t found a thing.
But, to you that fixed all the manuals. A big hurray
If I am reading this correctly, you found a set of RCA cables behind the deck and they go to the trunk. If you have a factory deck, I would not recommend trying to 'bridge' them. If you wwanted to do this, you would need a line converter, but they degrade the quality of the audio. Get an aftermarket deck with preamp outputs on it and plug the RCAs into it.
Do you have power or ground cables to the rear, what about a remote turn on lead??
