Old Apr 15, 2010 | 10:13 AM
No Warning Shot's Avatar
No Warning Shot
Default Re: Overheating, Repair Shop Says $875
FIRST -- Check and see if your car is covered under the recall for this problem!
Mine was not in the build range under recall but it still decided to call it quits anyways. Good thing I don't drive a Toyota! Anyways, I went up the block to my uncles Chrysler dealer and even with my discount Chrysler wanted $400 just for the new fan motor. I said screw this I don't want this POS OEM part that is known to fail and I went on eBay and bought a whole new shroud, fan and motor assembly for about $100 even and installed it myself. It's a 15 minute job. Havent had a problem since.
The only problem I had was the connector. They will slide together but not latch the whole way but it's tight enough to not worry about.
