Originally Posted by bmorgan
The back ones are pretty easy. The fronts are a bit of a pain. The main pain with the fronts is getting the "A" arm to line back up to get the bolt in. I have not worked on a car since my teens until I got the crossfire, and I was able to do it with no problem. To cut the springs, you will need an angle grinder with a cutting wheel. If you do not have one, I could cut them for you. Attached are the instructions that I used to install mine.
EDIT: Others have said the fronts are much easier if you have a spring compressor, which I did not have. You can get one from Harbor Freight for about $13. A spring compressor is definitely not required to do this though.
Here is a link to an easy to follow tutorial
https://www.crossfireforum.org/forum...5-srt-6-a.html. The pdf attachment is a combination of two posts.
the common spring compressor wont work bob. you need a european setup which i have and its such a pain in the a** to use i tossed it on the floor and did it the old fashioned way!!
