Old Apr 17, 2010 | 09:01 AM
Buggin's Avatar
Buggin
Default *Needed* 25 to build Wavetrac Limited Slip Diff unit
Finally got a response from Wavetrac, no response from numberous e-mails to Quaife.
Looks like I need to find 24 more people that would be willing to buy one for them to produce a unit... I was hoping they would do it with 10-15 confirmed.
See thier e-mail below. I know this is kinda expensive, but who is 'seriously' interested?
*EDIT* Looks like we have 10 interested so far between Benzworld and Crossfire Forums
Also note: This will fit the SLK32, SLK320, Crossfire SRT-6 & N/A
e-mail reponse:
Hi Alan,
Thank you for your interest in Wavetrac.
Sorry for the delay in response, we had a website/email issue.
As you know the phantom grip solution does not solve a spider gear failure. The only real solution is to build a stronger diff, and the Wavetrac is not only stronger, but will transform the way the car handles and accelerates, and is maintenance free. A Wavetrac can certainly be built for your application, we just need to produce enough of them to make the price sensible. We would need a sample rear axle and axle flange/inner joint to be able to design a replacement. The price for a diff like this depends on quantity made, and similarity to other current designs. I would estimate that with an order for at least 25 units in hand, that we could produce a Wavetrac that could sell between 1300-1500 dollars each.
If that sounds possible to you, please get in touch with me and we can sort out how to get started.
Regards,
Dana
_________________________________________
Mr. Dana C. Clark
Manager, Technical Operations
AUTOTECHdriveline
29 Journey
Aliso Viejo, CA 92656-3333 USA
Tel +1.949.362.8700 x25 Fax +1.949.362.8720
