Old Apr 18, 2010 | 09:34 AM
oledoc2u
Default Re: Best shocks for comfort on SRT6
Originally Posted by 32krazy!
doc i was able to lower my car a small amount with pads. its not much but enough for me. with the konis i can soften the ride while cruising around town and then stiffen the fronts at the track. now if you want the slammed look (which is great but the ride sucks!) springs are the only way to go.
The only way to change a spring rate, is to change the spring...you can cut them, but I would think the rate would remain close to the same...shocks control what the spring does...without shocks you would just bounce up and down...the shocks control that up and down motion. The longer the travel, the better the ride...
