Old Apr 18, 2010 | 09:44 AM
32krazy!'s Avatar
32krazy!
Default Re: Best shocks for comfort on SRT6
Originally Posted by oledoc2u
The only way to change a spring rate, is to change the spring...you can cut them, but I would think the rate would remain close to the same...shocks control what the spring does...without shocks you would just bounce up and down...the shocks control that up and down motion. The longer the travel, the better the ride...
quite correct doc. i wasnt thinking spring rate as i cant find if the 32 springs and the 6 springs are then same. my ride for the most part wasnt bad not really stiff, but i wanted the slammed look. it cost me in the fender dept as i went to low. so my oem went back on and the konis allow me to soften the bumps in the road while cruising. im tempted to get bmorgans springs to cut and play with but its such a hassle to drop the supension parts im thinking just leave well enough alone!
the op just wants a softer ride so maybe the konis would be a good option for him
