Originally Posted by JHM2K
In the few months I've been driving mine, I know for a fact that the launch/first 60' is where this car really sucks at life. Although, I haven't had the brass to do a 4500RPM launch, either.
But these cars are far too light and far too hot once you get 'em rolling to be confined to the 14's until death do us part.
I think it's all in the launch, clearly. Fastest N/A time I've seen prior to this was a 14.7 and you've beaten that consistently by .3 every run... with stock paper, nonetheless. That's a testemonial to your driving skills. Most people claim that a good CAI can drop .4/.5 off your ET. Add a tune, and I see no reason why it shouldn't be good for another three tenths off the bottom line. Add injectors... you get the idea.
I still think Franc needs to hit the track... he's comfy with a 6-speed and has about $2,000 into his motor. But, he's never raced his. If he can't crack 13's, somthing's up.
Thanks. I should no problem running a mid 13 second time with a full bolts on N/A car. For some reason I always claim "unrealistic" times and get laughed at a lot but then when I back it up, something is up with the clock or something hahaha
You are right, if he catn run a 13 second time, something is up.
Originally Posted by +fireamx
Muscle, try to find yourself a set of stock 18" front tires, and mount them in back. Disconnect your traction control so your smaller tires woun't cause you any problems. Race with your wing down, see what happens.
I hated the fact wing deployed each time, I think She is making me lose a mph or 2. and maybe a .1.
I will try what you recommended, all I need is a fellow crossfire owner to cash his ride up for me at track, swap the wheels real quick for a few runs. For the wing, I guess i need to pull a fuse right? Is there anyway i can simply disconnect the switch from the wing's motor at track?
