Re: Thinking of Stamped Concrete
Properly done in the cicago area concrete would be the best way to go for ease of maintainence. Stamping would create some snon removal issues but pavers on tha alluvial clay would not be stable and therefore worse.
Either would be best done with no less tha 6 inches of free draining base (# 3 clean or better) overlayed with 2-4 inches of 1" with fines. All compacted.
The base is the most important aspect of the job. Prperly intalled pavers or Concrete would be fine.
As for snow removal, the pavers allow for draining and they create a rougher surface so removal of all the snow isn't required. Any salt or chemical melt will go into the gravel base and be nuetralized.
Stamped concrete will have fewer weed and other maintainance chores.
Pavers are less expensive only if you do the labor. You also will have the ability to change your mind and redesign or add pavement later if yor wife suggests a change. What are the odds of that?
If you do pavers be sure to use #6. The #4, which are patio pavers (Lowes and Home Depot style), cannot hold up under a heavy vehicle.
But your Crossie and your mini would be fine.
As a H&G weekend warrior I've done my share of both although stamped concrete should only be done by someone who has experience. Not for the beginer. I prefer pavers for the architectural possibilities and the flexibility of change and additions. But in your area, I would go with Stamped concrete.
Don't go cheap cause I'm sure you aren't flipping the house. Properly installed, stamped concrete with a good stain or dye job will look awesome for 20 years.
roadster with a stick
