Old Apr 19, 2010 | 01:34 PM
Musclefan21's Avatar
Musclefan21
Default Re: Finally went to track! Results and videos inside
Arrogant much? you say you have been racing long enough to do the calculations and making negative assumptions about peoples driving ability, some of whom have been racing since before you were a twinkle in your fathers eye. If I were you, I would look to the people who came before you, or you will be destined to repeat their mistakes.....
You are not following what I am saying. I am not saying an XF has 600 ft lbs out of the hole, but as I stated, she has plenty of torque not to bog on a launch, ask the guys with the auto trans. This is because of the CDV I tried to explain, if you have never had a nice Euro car, you have probably not even heard of them, many members here have not. Do a little research and see why YOU DO have plenty of torque, but the parts are not letting you put it to the ground the way you want to, read:
CDV
I am not a drag racer, and I try not to be a ****, but respect for people who came before you and those who know their cars well enough to know why they function the way they do is a must, IMHO.
slow down there killer! nobody is giving you trouble and you call me arrogant! 229lbs of tq IS NOT plenty for a car which weights 3250+lbs with the driver. thats a lot of weight to push out of the hole. Yes I see what you are saying the electronics not allowing the car to do what it can do efficiently but even without the electronics, I see this car falling on its face at a hard launch instead of hooking and just flying out of the hole. I had a trans am with 330lbs of tq with no electronis to limit the car and when i launched that thuing at 3000-4000rpm it would bog (with sticky tires) because the weight was too much for the torque the car had. If our caqrs weighted 2500lbs then i would say 229tq is pretty decent amount.
If you say the car PLENTY of torque then this car without the limitations should be able to cut a 1.6 60's easy? Well I will tell you this, you arent cutting any better pretty much a 1.9 60' with a stock xfire.
And about me commenting on otherss driving ability, well guess what? some people just can't drive. Period! And so what if somebody was driving when I was a little kid taking a dump to my diapers? is that mean they will always be better at it since they have been in it longer? Look, I don't like to talk about my driving much and I like to show times and call it a day, but you get me a full bolts on crossfire and watch me run 13s CONSISTENTLY.
