Old Apr 19, 2010 | 03:00 PM
BoilerUpXFire
Default Re: Finally went to track! Results and videos inside
Originally Posted by Musclefan21
slow down there killer! nobody is giving you trouble and you call me arrogant! 229lbs of tq IS NOT plenty for a car which weights 3250+lbs with the driver. thats a lot of weight to push out of the hole. Yes I see what you are saying the electronics not allowing the car to do what it can do efficiently but even without the electronics, I see this car falling on its face at a hard launch instead of hooking and just flying out of the hole. I had a trans am with 330lbs of tq with no electronis to limit the car and when i launched that thuing at 3000-4000rpm it would bog (with sticky tires) because the weight was too much for the torque the car had. If our caqrs weighted 2500lbs then i would say 229tq is pretty decent amount.
I did not call you arrogant, I called your grandstanding arrogant. Saying you can easily do something that many before you (with more experience) have tried before. Some have been racing this car for 6-7 years, you made claims after having had yours to the track once. I also said you had good runs, which you did.
Also, must not have looked at the info I posted because if you had read even the beginning, you would know this is not an electronics issue, it is literally a delay valve, totally mechanical. This means you are not putting out the 229tq that the car is able to produce until the entire clutch is engaged, which is delayed by the valve. I did not post this info to make myself sound more knowledgeable, I posted it so others, like yourself, who race, can use the info to try and gain an advantage. Everyone is throwing thousands into their engines, and the thing you need in a manual to really put the power to the ground is being delayed by a $2 part.
If you say the car PLENTY of torque then this car without the limitations should be able to cut a 1.6 60's easy? Well I will tell you this, you arent cutting any better pretty much a 1.9 60' with a stock xfire..
I never said anything about 60's, like I stated, I am not a drag racer, but I have been around a track or two. I simply said that if you were able to put the tq to the ground ALL AT ONCE, you might not be complaining about a lack thereof. I brought this up,
And about me commenting on otherss driving ability, well guess what? some people just can't drive. Period! And so what if somebody was driving when I was a little kid taking a dump to my diapers? is that mean they will always be better at it since they have been in it longer? Look, I don't like to talk about my driving much and I like to show times and call it a day, but you get me a full bolts on crossfire and watch me run 13s CONSISTENTLY.
I would really like to know what a full bolts XF is, and how far into the 13s you are intending to go, then we can continue our discussion. But if you have no intention of wanting to learn more about the car, like not reading what I posted, that is your choice.
