Re: xfire oil change requires blood sacrifice
When I finally had enough brake dust I finally did the brake pad change to Rotex and got some cheap jack stands. If you carefully position your floor jack on the xfire jack pad and position your stand on the same pad you can lower and be safe on your stand using the same jack point.
